Bear77
South FL
Nice! Looking forward to updates!
I got to get used to the new fobs, but I do kind of like the feel of them so far! Was going to order the brake lines but wasn’t sure. Got confused between Russell or Goodridge. Russell has 5 lines and Goodridge has 6 listed?
Dantheman1540
Sugar Loaf Mountain
Uh oh replaced the sensor and it will start with throttle applied and continuing throttle will keep it at a rough idle but there's noise on the passenger side of the motor. Maybe a broken valve spring?
It doesn't sound like a knock almost sounds more like piston slap or a lifter not pumping up, has good oil pressure still.
Going to try to pull plugs before I have to run back to work.
Do not like. Hoping for the best.
Pretty sure you need to do a relearn when you replace that.
Mezzo
Decided to bite the bullet and ordered this...
Also waiting on this to come in...
As well as this...
Ive seen that key fob from a guy on YT LSXMatt,its suppose to be super easy to synch up,been thinking about getting one of those.
