I have never had a problem with one.
where the bolt goes on it can pivot a little if it moves a little it wont make contact, if you ever loose your brake lights or cruise and the fuse and bulbs are good then check down under the dash and try pivoting the switch up. doesn't matter how tight the bolt is it can still move by hand it doesn't have a notch or ridges just smooth plastic edge on a smooth metal edge.
*when I had my 00 it happened a handful of times over 12 years, I thought the switch had gone bad and went to replace it and discovered it could turn a little, turned it back up and walla, I don't cruise much but whenever someone would say "you have no brake lights" I knew exactly what it was, hasn't happen on the 12 yet but it's the same design.
Trackman
