Parking Brake not working correctly
00'BlueSteel
Carolina
My parking brake is only engaging on the driver side.
Put the truck up on jack stands, put it in neutral, and put the parking brake on. I can still freely turn the passenger side wheel. The driver side grabbed a decent amount but not enough to hold the truck in place.
I started checking the cables and found that where the 2 cables come together into the metal bar that keeps them even they weren’t pulling evenly. It was pulling the driver’s side cable a lot more. Like the passenger side cable was stuck or like the drive side cable was stretched out.
I had a helper get in and engage and disengage the parking brake while I was watching it all. What I saw was the lever that the brake cable is connected to and comes out of the dust shield on the passenger side only moves about half the distance it should and stops. I think something in the parking brake that has to do with that lever is jammed or out of place.
I have tried searching for more info or pictures of the whole assembly and what that lever is connected to or what it is called and can’t find anything. Any help would be awesome.
Chubbs
have you ever replaced the brakes shoes on the back wheels? you might start with the parking shoe assembly if they are the original pieces. If that part is out of whack or coming apart then nothing upstream is going to look right.
00'BlueSteel
00'BlueSteel
Carolina
The parking brake shoes were just replaced. I think the person who did it, my dad while I was out of town, didn’t get it back together correctly. Which would surprise me because he has been doing it since the 60s.
I need to open it up and look but I was hoping for some part name/number/pics before I dove in. I dont mind ordering parts before I started and returning what I dont need when I am done. I just don’t even know what that lever connects to, lol. I see pieces that look like the lever in Ac Delco’s parking brake kit for these trucks. But what does that lever push against inside the brake assembly.
Chubbs
i don't know how much you mess around on YouTube but you can find a tutorial for everything. I have watched at least 1 for the parking brakes.
When you get time do a search on YouTube for 'parking brake tahoe' or 'parking brake yukon' and skim through them til you get a handle on the procedure. I wouldn't watch 99% of these nuts from start to finish, but there are a few who are pretty smart and that I follow closely. I will hook you up with a few links later when my wifi speed picks up.
Get yourself a subscription to AllDataDIY for all the photos and part numbers and procedures and such. If your old man has been working on cars for 50+ years, he's an old timer and his memory is likely not what it once was. Mine sure isn't and I'm not quite half his age, started working on cars in the 1980s.
Chubbs
Let me know if he does parking brakes in this vid
If not, this ought to get it
00'BlueSteel
00'BlueSteel
Carolina
I usually watch 1A Auto videos, they have a 2000 Suburban they do just about everything on. To be honest I haven’t watched the parking brake video because I know how to change them. Just dont know the name of the parts, and my Hanes manual is lacking on info. I’m going to watch it tonight, thanks for the help and the vids, I’ll watch those as well.
I have read about AllDataDIY a couple times now, I guess it might be time to sign up. Not bad for 5 years 1 vehicle. And yeah he still has the skill but the memory isn’t as good as it used to be, but I also think something might have just broken or slipped out of place when he was putting the drum/rotor back on.
David Kriss
I'd also check the passenger side cable itself for binding. You may need to replace or lubricate it. I had a simiar problem that was the cable. Mine locked up with the brake partially engaged. Cables don't like all that dirt and corrosion they are exposed to.
I would get it apart and then verify the cable is engaging if that is good then simply adjust the one side as needed
rddixon
