Chuck_Finley
- Joined
- Dec 13, 2017
- Posts
- 122
- Reaction score
- 120
That's awesome, must be great for the kids on a road trip.
The simple adapter does not work ( I tried that first ) but the converter box was just a few bucks more... and yes I did tap into the power source you referenced under the armrest of the truck. I did the extra spicing work to make the instal cleaner and still allow me to use the plugs for anything else that may come up later on down the road... I have 4 kids so I have to make sure all the outlets are always available for trips lolThere may be an easier way. I just realized this setup is special because its with the OEM HU. There is an A/V to HDMI cable you can buy off amazon which would convert the A/V output on that back panel to HDMI. Wouldnt that alone allow the Roku, Amazon Fire stick, chromecast work without any other additional work? Similar to plugging an old video game system. You could power it with the cigarette lighter under the center armrest too.
Just realized it wouldnt be hidden without something custom done so this route you went seems pretty good
Sorry no as this was just a warm weather day project I did when I was bored as we had an upcoming long distant trip a few days later. As another member pointed out to me before i started the project the black panel literally just pops off and everything is easily accessible from that point on. Depending on how hidden or not you want it to be, it can be a simple plug and play just like you would inside the house.You have any step by step pics of the actual install?
Everything is tucked behind the black panel; enough room for then Roku, converter box and all the wiring.Probably a stupid question but where are you keeping the roku while running it? Is it hidden?
Wouldn't turning on/off the Roku via the accessory power with each car start quickly destroy the flash memory in the Roku rendering it useless?
