Finished adding Roku Device to the Truck
delightskinned1
Northern VA
You talking about splicing into those cables in the console?
Was Pretty easy this is what I used...
* Roku ( or any streaming device )
* HDMI in Composite cable out converter box.... Both devices require power
* Additional GM Video Input terminal GM#10375379 ( or splice into the existing one )
* AV cables to connect the two
Everything is tucked and powered from neatly behind the panel, did not even have to unscrew anything!
Other than the roku which was just a spare I had in a drawer everything cost about $30 total off of amazon.
Mrhug3
Midsouth?
What did you do with the additional terminal?
delightskinned1
Northern VA
I installed it So I could keep everything hidden and still use the original set if I wanted to play something else... For $9 it cost kept the install a lot cleaner. The most important part is that box Because just a standard adapter won't push the signal because of the older style hookups on the truck
Mrhug3
Midsouth?
Did you just unplug the original and leave it in place? There is a Roku now that uses RCA style connection. I'll just get that.
denalianyone
NYBlackLade08
New York
How did you go about splicing into the AV cables. What colors on the input rear console did you splice into?
dzg9
