Spare removal
HiHoeSilver
Away!
Chicago
Nope, at this point i cant even get the tool to the point where its supposed to go or even see where its supposed to go due to that plastic piece.
Is the tire sucked up tight, or hanging just a little so you can kind of "swing" or around?
HiHoeSilver
Away!
Chicago
It's in there tight. No slack at all. At one point we had the winch rotating but it never lowered.
Even if you get it to start coming down, that stupid secondary latch is gonna be stuck and you'll end up fighting with that, too. I think if it were me, I'd put your jack to help hold the tire up and use a hole saw around where the cable comes through the bottom piece, if that makes sense. I'll look for a picture in a few minutes if you don't get what I mean.
Scottydoggs
NJ
i wonder if you could let the air out the spare tire fully. then jack the wheel up tight, then finagle the holder part through the wheel.
K
KilluminatiDre
id cut that cable nipple end off with a cut off wheel, that lead end its likely the cable clamp. or cut through the spring area.
Yea im gonna try and cut that off with the dremel wheel when i get back home. It cuts through metal pretty easy. Ill let the air out too.
Scottydoggs
NJ
no need to let the air out if you cut the cable. but i would support it so it dont drop on you.
aces-n-eights
Alaska
When I got my '06 the same thing had happened to the previous owner. He cut off the "ears" of the piece that spans across the hole in the spare. Replacing that part was cheaper than replacing the cable assembly. Just a suggestion...
As a side thought... Many new cars come with a can of Fix-A-Flat (or similar) and a compressor. Any thought to dumping the spare entirely and carrying those items?
K
KilluminatiDre
Ok I'll give it a shot
That makes sense about the ears., I'll cut those off. I keep an air compressor with me in the truck so I do plan on ditching the spare. I just need to get fix a flat.
mommy2boys211
