Opinions on Aftermarket Motor Mounts? '07 Yukon XL Denali
The difference is the stock mount is a hydraulic mount (it's a rubber bladder filled with fluid) which is supposed to decrease felt vibrations.
The Hummer mount is solid rubber and much less likely to tear and fail.
Bingo^^^^^^^
justinesky
I changed mine 6 months ago and it seems i may do it again. is that the hummer mount part# listed above?
justinesky
another question, it appears that the 5.3 and 6.2 MM are different. do they make a solid MM for a 6.2?
NGAneer
NWGA
Just get the passenger side part number for an H3 with the 5.3. You can find it on rockauto.
im probably going to order one myself soon I keep getting a clunk and not sure if it is a motor mount or slip yoke yet
justinesky
still confused. so the hummer pass side motor mount is the same part/mount for a non hummer truck 6.2 for the left side? i am trying to find a non-liquid filled mount for my escalade
DesertGator
