DallasTahoe
Got tired of inconsistent brakes so I got my nbs master cylinder and my simple brake proportioning valve set up and ready for my ABS delete installation tomorrow (crossing fingers)2418acfc3f4a7cfc8c377b67558933ce.jpg
DallasTahoe
Finished up my nbs master cylinder upgrade and my abs delete with no big issues and I didn’t even have to take the abs warning light bulb out of the dash, she stops pretty dam good even before doing a brake bleed, that’s next! 5f5ed1c42dd84c38b15aa8e583e51729.jpg
1BADI5
DMV
Installed this in the Yukon today.
I got all of the lines for the backup camera run, BT Mic installed; just need to get the camera mounted on the back of the truck (under the bumper)
The camera and streaming music via BT is an amazing function to have.......its going to be great for commuting
1BADI5
DMV
FYI - if you have a rear view mirror with the temp or auto dimming....... you can tap the harness under the A-pillar plastic. Its a green wire, I used a test light to verify the wire
The other 2 option are - 1) reverse lock out harness on the side of the transmission 2) tap the reverse bulb wiring at the back of the truck
jiggie
Got some new tires yesterday. Ditched the junk bridgstones. Went from the stock p255/70/16 to a LT265/70/17 all terrains in 10ply. Chose these cause well first they were affordable, 2nd they had good ratings on tire rack and they have the 3 peak mountain snow flake symbol on the side so ill be cdot compliant when we go to colorado in a few weeks. 85021b81a0a1c02552555ada5e845bfd.jpg3a55c9a1b7f64f2b36cf47ba1490dca3.jpg
Sent from my LG-M153 using Tapatalk
Jayebarberr
