Added OEM back up cam to aftermarket radio
harrim
Upper Marlboro, Md.
I have been searching for information on installing a rear camera in my 2013 Tahoe and came across this post. I recently purchased a Rosen GM1210 unit to replace the factory radio and an Advent cam335 for the rear camera. Installing the head unit is not a problem but I am trying to determine how to install the camera where the existing applique is. The applique appears to be some type of hard plastic, so I was wondering if I could use some type of glue along with self tapping screws to connect the camera mount to the applique? Any suggestions? I have seen a couple of videos describing the removal of the rear panel so I don't think that will be a problem. Also, any suggestions on how to get power for the camera?
NathanJax
NathanJax
Vacation Nathan
Administrator
Jax, Fl
You can do that, yeah.
under the dash you can grab power, ground you can self tap a screw to the sheet metal
Ron C
Los Alamos, NM
So my truck didn't come with the Nav so it didn't have back up camera. I purchased a factory back up camera off eBay for $40. Purchased a 12v to 5v converter from a member here (was an extra that he got it off eBay)
Factory camera
I cut off the factory plug. There were 4 wires. Red, Black, Yellow, and White.
Red = 5 volt
Black = Ground
Yellow = Positive (inside RCA) video output
White = Negative (outside RCA) video output
Wired up the 12v to 5v converter as the sticker shows, and soldered a male RCA end to the yellow and white.
I kinda went with these instructions as to dremel the rear applique
Adding a back-up camera
Outside like OEM...
and inside when I go in to reverse, or I can hit the camera button on the screen and the camera will stay on indefinitely.
Wow cool!! that is exactly what I was looking for.. great write up!!
Ron
NathanJax
NathanJax
Vacation Nathan
Administrator
Jax, Fl
On ebay I also saw the ones that have the rear glass button AND/OR the camera. so there are several ones?
Ron
no idea. I thought they all came with the rear glass button so its just the option to add camera
Ron C
Los Alamos, NM
Chuck_Finley
I am about to mount an aftermarket cam in the same location that just needs a single 1/2” hole for a bolt, can I just drill through my factory applique?
Off Road Pedia
