Can't start in the cold
H
harbison
Voltage is 14.6 when running. There is a ground wire to the chassis at the cross member just in front of the tank. We may try soldering the pigtail instead of the crimp connection.
east302
Mississippi
During this latest episode, was it cranking at normal speed (just missing fuel, air or spark) or was it slow like you'd get with a low battery?
H
harbison
Well after a week of trying everything but the fuel pump, I finally gave in and replaced the fuel pump (it was only a month old). This time I soldered the connections instead of crimping. 60 PSI with key turned on, engine off. This is the fourth replacement of the fuel pump in two years, three of those since the end of June. I'm wondering if the connection had anything to do with the failures. I soldered in test wires this time so I can check the voltage at the tank without having to drop the tank. Hopefully I won't have to go through this again but I'm not going to hold my breath!
H
harbison
It is running! Sorry I wasn't clear. Really like your Red Tahoe. Had a red over charcoal 99 Suburban.
willxfs
About 10 years ago, I had my fuel pump replaced by a shop. Not long after, I would randomly get a not start condition (motor would turn over strong, but no start). I took the truck back to the shop that did my fuel pump. The mechanic reached up over the tank and jiggled the connector to the fuel pump. Started working ok...for a while. Eventually the random no start condition returned. I could get it going by laying under the tank and reaching up and jiggling the connector to the fuel pump. I put up with this crap for a while till I got fed up, dropped the tank and replaced the damn connector (wiring harness side). Problem solved. I changed my fuel pump since then (proactively, because the damn thing was so noisy and it was 10 years old). This time I made sure to buy the AC delco pump that came with a replacement connector for the harness side. No problems since. And the pump is nice and quiet!
Thekenstar
