FYI - High Output Alternator
Martinjmpr
Littleton, Co
Was there an error message on the DIC? When my alternator went out in April I got a message on the DIC that read "Battery Not Charging." Was able to make it home (thanks to the dual battery!) and replaced the 145a alternator with a rebuilt unit from Auto Zone. Problem solved.
If there's no error message I'd suspect the battery, as others have said.
rockola1971
Indiana (formerly IL)
I would definitely suspect the battery since he said with key off it was at 12v... when it should be closer to 13v. If he is reading 12.0vdc then that battery isnt fully charged, has a load on it or has a cell(s) dragging the battery output down.
BigDaddy13440
BigDaddy13440
Rome, NY
It's barely been cranking over in the morning, at about 9-10v, temps have been in the 30's. Once running, the battery will charge enough to crank over almost immediately any time throughout the day, and stay at 12v+. BUT, I noticed over the past few days that running my stereo (only one amp, a 1000W), that even on a modest volume, the voltage drops from 14+ at 2000rpm to about 13v (and my headlights flicker), and when pushing that amp hard, voltage drops further, and my headlights and interior lights dim).
So yes, I'd also agree that it's the battery. But I also don't think the stock alternator is working at full capacity. So, I received the 253amp one yesterday, it's going in tomorrow. Bought a heavy lug crimper, going to re-work all the Big 3 wiring, and add the second battery. I do NOT want to have to worry about having no juice in winter here in NY.
The stock alternator puts out ~105 to ~160 amps, depending on which one you have. The battery should be somewhere around 700-1,000 amps. In simple terms, the battery is what powers your stuff, the alternator just recharges the battery. If the vehicle has a large power draw on the battery, a larger alternator is needed to "power through" that draw to charge the battery. Yes, everything is pulling off the battery and the alternator at the same time, but the battery is what supplies the majority of the ampacity to maintain voltage. You don't want 100 amps (big stereo, winch, etc.) pulling on your alternator at all times.
W8TVI
Traverse City, MI
I've actually put a pair of DC amp meters on the main wires from the alternator and the battery, and I found that no amperage flowed from the battery until I exceeded what the alternator was rated for.
I was quite surprised, and double checked that I had the right wires.
BigDaddy13440
BigDaddy13440
Rome, NY
Ran it yesterday, sat from noon until 8pm tonight. Only draw visible is the blue LEDs under the rear seats, very minimal draw, and the phone charger (status LEDs).
Wouldn't start, had to jump it, voltGe was at 9.2V.
from what you are describing that is a bad battery, lt may be just barely holding on enough to tease you to think its not. yank it and replace it or have it tested at the place of purchase. that's my .02 anyway from previous experience.
BigDaddy13440
BigDaddy13440
Rome, NY
Have to agree.
rockola1971
The battery is junk. It should me at a min 10.5vdc while the engine is cranking. The battery voltage should be around 12.5vdc when fully charged at rest. The only purpose of your battery is to provide the high amperage your starter requires to spin the engine over for starting. After the engine is running EVERYTHING that draws power is being powered by your ALTERNATOR.
Why are you pissing around with a $70 battery that is bad? A battery is not rocket science and many have provided correct information concerning your battery being bad. (Granted some have provided some very ignorant info here too).
Ive troubleshot bad batteries on the F/A-18, F-14, SH-60 and you know what, they arent much different than a automotive battery. Aviation use AGM now but same principles.
A battery is actually an incorrect term. It is actually a Container, Case or Jar that has a collection of batteries (cells) within. There are 6 batteries (cells) within an automotive container ("battery"). Each cell (Battery) is charged to 2vdc+ (typically 2.08vdc+). If a "fully charged" automotive battery's voltage is much below 12.5vdc then there is a reason which is usually a cell (battery) not being able to charge up to or over 2vdc. This is a "dead cell" that is not pulling its weight. There are two factors that determine the amount of power a cell within an automotive "battery" can produce. Voltage and Current output. Power equals voltage times current. You have to have both. Since all 6 cells are in series the max amount of current output is equivalent to the lowest cells current output. The others cannot make up for the slacker. It is the opposite for voltage. Other cells can add to the total voltage output and pick up some slack of a weak cell but the amount is very limited.
BigDaddy13440
BigDaddy13440
Rome, NY
Can't exchange it.till.tomorrow afternoon.
csan2879
