Adding/enabling tow/haul mode
Ron C
Los Alamos, NM
to be h
Yeah my PPV doesn't have that plus or minus or even the switch to activate urban lol.
To be honest, I just got it 4 weeks back. It's a 2013 SSV, and the trailer stuff... I have no idea how it works.
The switch under the dash is for a trailer with electrical brakes I was told. I don't know what the buttons on the shifter are for.
RichardCranium
Mebane, North Carolina
The Tow Haul mode revs higher in each gear as well as increases line pressures. You could find a tuner somewhere to make a custom tune that would be a medium between a driver/towing. Otherwise, the switch should plug/play but I'd bet the BCM will need to be flashed in order for it to work.
MidwestMike
Southwest Michigan
I used tow/haul with my 2002 Tahoe with this trailer. 285 HP with a 4 speed.
I just pulled this for the first time this weekend with my 2014 SSV, and did not need tow/haul, not close enough to the rated capacity.
I'm thinking the low profile bass boat towing won't need it either.
jeffbco
M5 prevents shift into 6 - not sure if 6 is called overdrive or not but with M5 it won't go there.
Solace
NJ
The wires are under the dash for a trailer package, but as mentioned above you will need your BCM flashed/tuned for the towhaul mode.
Ron C
Los Alamos, NM
Is there a way to determine whether that already happened or not?
Ihaveatahoetoo
