Wheel Spacer sizing
DWSmoot
Charleston, SC
Thinking about potentially adding some BORA hub centric wheel spacers. Does anyone have experience with and/or know the smallest spacers that can be run on these wheels without cutting studs?
Bigmac18
Yup... 1.75" Bora spacers were made specifically for the GM stud length
Bigmac18
It will push your wheel out about 44mm from where it is now, so depending on the offset of your stock wheels (+31mm?) you're probably close to a -12 offset wheel
I am running a 2" spacer with stock wheels (20x8.5 +31) and 305s just for some comparison:
full
DWSmoot
DWSmoot
Charleston, SC
full
Thanks BigMac. My wheels are 22x9 24 offset. Your setup looks good. Concerned mine would push out more even with a 1.5 spacer. Do you have any other pics at different angles?
Bigmac18
with a 20x9 +24 wheel and 1.75" spacers, yours will stick approx 1/4" further out than mine pictured.
agmanw8n
