Paint matched the front end
BeenChevy
Minnesota
+1 on the paint matched grill.
05Single - What's up with the oven cleaner now?
BeenChevy
Minnesota
Dave - do you mind specifying the process in more detail?
Interested in the process you used to split the housings open, how you applied/used the cleaner, and your process of sealing the housing back up with an adhesive. Want to do it right the first time around..
05Single
afraid of the dark
Bake the light at 205-220 for 3-5 minutes at a time to soften the sealant. Set them on a piece of plywood , not directly on the rack. Work a little at a time throwing them back in the oven to heat them up again. Wedging a butter knife or something alike along the edge only a few inches at a time then put them . Be patient, aftermarket headlight crack easy, oem are pretty solid, but take your time. My first set of lights I spent 45 minutes on each light.
Pm'ed
BeenChevy
Minnesota
Exactly the response I hoped for. Thanks for the detail Dave. I'll be trying this with 2 sets and taking photo when I get to it.
SRobinson541
