Do you guys have a way to delete 15+ magnetic ride
Fifty
there are kits to trick the computer for the 14 and older magnetic ride trucks...
Do you guys have anything in the works for the 15 and newer trucks/suv with the magnetic dampers?
They suck.
adam3
I'd love to find an answer as well because as fifty said, it sucks. I've tried a couple of different resistors on the front but have yet to keep it from throwing a "service suspension" light
F
Fifty
Can you list what you tried Incase anyone tries as well
adam3
Measured resistance and tried something like a 1.5 ohm I had laying around, didn't help at all. Then gave the 3.4 25 W that worked on previous years a try and worked for about 100 feet until I put it back into park. Haven't messed with it since.
I threw on a set of belltechs after the dealer wanted $1,800 to replace the leaking factory mag shocks and the ride has substantially implroved...just have an annoying light with speed restriction
F
Fifty
Ugh. What’s the speed restriction?
I wonder if that can be tuned out?
@JennaBear can your guys tune out suspension error codes?
adam3
Speed restricted to 85 or 86 mph... honestly, not that bad but cruise control is also restricted to 80 mph (will not allow you to set it above that).
I rarely need to go any faster but it's just an annoyance knowing that I can't
Justin
Sorry, there is nothing that we can do about magnetic ride at this point.
F
Fifty
Well snap to it lol!!!
C’mon! Be the first, make millions if not hundreds of dollars!
GTNator
They suck.
Why does MRC suck for you?
BattleBorn
