Jerry's POS NBS crew cab
Administrator
my bag kit is from Mcgaugh's . I was originally going with the "slam air" kit from Air lift but after talking to the air lift rep they are only rated for a truck with 5" of drop in the rear. there is a chance I may drop another inch or 2 so I didn't want to chance it.
Is this the kit you got?
https://www.summitracing.com/parts/mmc-33069/applications
I've already got my eye on a compressor thanks to a recommendation from @Yuko04 so just need a kit like this without a compressor
jerryjoe28
jerryjoe28
That Guy
cabot AR
yates ™
Resident Apple hater
Iowa
Yuko04
"SquareBODluvr"
MN
Any Viair compressor above 400 will do. Ive just had good luck with them. They run my horns and airtools. Its all manual. I have no clue on the wireless system. I didn't want that.
"Square Headed and Dually noted"!
yates ™
Iowa
Any one under that would be fine for helper bags. @07Burb and @jerryjoe28 it is really what you want. I can help you design a tankless system or you can run the air lift or you can run a tank like @Yuko04 is talking about. Any of them are good it is just the options, budget, and what you want out of the system.
jerryjoe28
jerryjoe28
That Guy
cabot AR
I wanted the option to so that I can take some lean out and be able to fine tune but to answer your question, probably not.
lord knows I have the "chevy lean" im going to flip my shackle mounts back over and I think set one side lower than the other on that
golavaman
