Low cost 3" lift
dubfreaks
Philly
Whats out there for a decent lift without killing my wallet. 03 Z71 with 230k on it don't wanna spend too much money on a truck with this kind of miles but still wanna weigh out the possibilities. Thanks fellas
dubfreaks
dubfreaks
Philly
crank keys and rear springs. Or rough country.
Don't know what any of that means dude, this is my first truck, I've been a euro sedan guy so I'll tell you all about lowering but not a thing about lifting a truck. Of i could get a lot with everything I need I'll be golden.
73impala
Margate, FL
You have torsion bar on your truck. They go from the LCA to the torsion bar bracket. Inside it are what they call keys. And if you crank the bolt that holds tension on them it'll lift the truck. You can also get aftermarket lift keys and it'll lift it more. Now doing it this way will make the ride rough but its the cheapest way. You can also get rear lift springs or cups that go under them to lift the rear. You will probably need shock extenders too.
02_Tahoe
Maryland
This is what I got
Wheels and tires off Customwheeloffset.com
inmypassatlife
Euro sedan guy? Your TDI get bought back too?
