Door panel lights
ivin74
05 NBS Nali
Htown, Texas
My driver side door panel light does not turn on when ai open the door. I changed out the bulb and still no light. Does anyone know what triggers the light to turn on?
05Single
afraid of the dark
Check the plug , might have corrosion inside and not getting a good connection.
Maybe a pinch in the the wire in the door.
Did it ever work before ?
M1Gunner
Gainesville, Fl
lol what @HiHoeSilver said! Any other symptoms? (Thanks for the shout out)
Does your radio stay on with the key out, do you get the "driver door ajar" message?
EDIT: since you already did the door latch disassembly and cleaning...
if you have a multimeter, you can back probe the harness at the light socket and check for power. Also check for a good ground but make sure there is no voltage on the circuit first before you check resistance/continuity or you will blow your meter.
ivin74
ivin74
05 NBS Nali
Htown, Texas
I did the rebuild and everything is working like new, thx
Great write up
Laurents10
