LED drl
Crippin87
Crippin87
Oh gotcha yea I would probably just go that route then, the 2 set looks better to me but it's all personal preference lol
95escahoe
Just ordered the 2nd ones had a similar set on my OBS Tahoe
jaywoo65
Cabot, AR
Within the next month or so I'm going with these I think:
http://www.ebay.com/itm/381180235199?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
05Single
afraid of the dark
Na it's still a NBS the Escalade headlights have a plug going to them, so all the pigtails and wiring is inside the light
Thinking about these ones I've had good luck with Depo in the past
LooKS like a black and white pic. Might still have the amber reflector
TheAutumnWind
I have not seen my drls lit up yet. I've got the led drls in place.
the blinkers worked and hyperflashed so I swapped the incandescent lights back in until I got my resistors.
95escahoe
If you have the keyless entry unlock it around dusk or early in the am they should go on then that's how I checked mine on the Silverado
TheAutumnWind
still no LED DRL's on. My bulbs were pretty burnt up wonder if the sockets are burned out.
Might throw a 3157 ive got laying around in one side and see if it works.
If I have to splice in new sockets I may as well do the 4 DRL mod
95escahoe
You can get new AC Delco pigtails on Amazon cheap had to splice in new ones on my Silverado
05Single
afraid of the dark
So you're not even sure if the bulbs turn on?
Hook up a lead to the battery and touch the bulb to it to see if those even light up (I have a loose 3157 base socket with a long lead to test bulbs, easiest way). I've received a pair of bad bulbs before off ebay, rare but it happens. If not contact the seller asap.
Or try putting in regular filament bulbs in the drl spot and see if they come on. If not then check the fuse?
Slowassc10
