Inside of Center Console Missing
bwhite220
Northwest Arkansas
Just picked up a 2012 Yukon Denali from the dealership. The only thing that the truck needs fixed asap is the inside lining of the center console. It looks like someone tried to clean it with a chemical and accidentally removed part of the lining.
Do you guys know of anything that I can do to restore it? Either a new lining or even some kind of an inset that can go in there? As is, it looks kind of disgusting.
sk1dm4rk
Go back to the dealer and make them fix it. You just got the truck, right? They're still in "impress the customer" mode.
Give them a chance, they will likely make it right for you.
VDV18
If this is the only thing that needs fixed ASAP, consider yourself in pretty good shape :waytogo:
bwhite220
bwhite220
Northwest Arkansas
I tried and they said that when I drove it off the lot, it became mine. Sold as is.
I'm not going to push it too hard because the truck is in great shape and this is the only thing bothering me. There has to be some kind of an insert or something. Or, I'll just take the rest of the lining out so it's all plastic inside.
sk1dm4rk
Wow. Apparently, impress the customer doesn't last as long as I thought. Was it a GM dealer?
if you post some pics of the problem you may get more responses.
Good luck.
2011SSVHOE
I'm an egual oportunity offender
The Heart of The Triad, North Carolina
find a stereo shop and get some of that greyish black carpeting that they use on speaker enclosures and install with some 3M type 77 spray adhesive. just my 2cents worth!!
while I am at it Welcome to the forum!!
cwebb
This worked wonders, it may be a an option and it comes with the fuzz type of lining on the interior instead of hard plastic.
http://www.ebay.com/itm/282277792824?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
cpellegrino
