LEDSs headlights package
AngelXL
AngelXL
I end up ordering this set from a local guy here in NY. He is on ebay. Pretty good price. Will keep you update with result.
I'm doing High Beams, Low Beams and Fog Light.
The only ones that did not fit were the H16. The rest is fine and is enough power/lighting even if is 30 watts like one member mentioned and I drove in some boondocks out in Easter long island... I'm very happy with the product. 2 months and counting
ajs800
Michigan
still no issues?? Can you really hear the fans running? When researching leds as headlight bulb swap, i have read many times not to waste your money with leds with fans...they will soon fail and overheat. Additionally, aftermarket leds don't compare to the distance and direct light that halogen/hid provide in projectors for low beams. I guess that's why new cars with oem LED headlights have multiple projectors.
I know it's more work, but I think I'm going to stick with orig HID setup using oem type ballast and philips 4300k bulbs.
AngelXL
AngelXL
No issues here and lighting is great. Good luck with your install.
4armo
Went with the LEDs AngelXL recommended. I put the fogs in first and drove with them and the stock halogen for a while. I'm not sure I would go with a brighter fog, sort of just splashes light everywhere. Got flashed a couple times. Great as DRLs tho.
After I added the headlights I got a text from GM with a warning about multiple lights out. Nothing on the dash. Light output is a bit better than stock, color temp obviously bluer. I would say maybe 10-20% more light. But looks great from the front, with the lows and fogs matching the LED strips.
Below are pics with one headlight installed for comparison. Then all lights.
Will let you guys know if I have any issues.
joshs2000ss
I just got a 2016 SLT, I'm looking to upgrade the headlamps and fogs to match the rest of the LEDs, but I'm a bit concerned. I know what the output of a LED flashlight looks like compared to the old style halogens. Do these headlights throw the light well enough that you aren't sacrificing visual distance at night?
Denali132
Banned
I was going to go with LEDs for low beams but I just don't trust them for my low beams so I'm going to go with Vanquish Autos HID for low beam and their LED for high beams I think. I love the 80 watt LED fogs and they make a HUGE difference
Sent from my Samsung Galaxy S7 Edge
ajs800
Michigan
I considered LED for low beams but didn't care for light pattern and lack of distance and stuck with HID with Phillips bulb setup.
Denali132
Banned
What set up and where did you get yours ajs?
Sent from my iPad Pro using Tapatalk
dapperdadman
