2005 ppv tahoe shocks
Lit549
I just tecently bought a ppv tahoe,does anyone know what shocks i can put on it?Imay lower the truck but only after I figure out how much it was lowered from factory.Im not going that low maybe 3 in more in rear and 2 front.but for time being it really needs shocks.What can I put on there that'll be best form but smooth ride?Thsnkd
Lit549
Lit549
Lit549
Lit549
Here's 0assenger side,1st pick the rear looks a litter higher because where it's sitting..
TheAutumnWind
Whats the ride height? Looks similar to my nali which is 34/35" from ground to fenderlip. Thats ~ 1" lower in the front and 2" lower in the rear from typical. I am running stock length bilstein 4600's.
Lit549
Lit549
The front is 33.5,rear is 35.25..So im thinking you are correct 1 in on front,2 in rear..So im thinking a 2/3 drop wouldnt even be worth it,may as well do a 3/5..I am also running billstein hd's.
TheAutumnWind
Agreed. 2/3 isn't likely to get you much if anything.
TheAutumnWind
What do the bumpstops and jounce stops look like on that rig? Do you have shock relocators? Curious to see how those vary from a typical 'hoe
Lit549
Lit549
No shock relocaters,and i can take pics of stops,what is the jounce stops?
TheAutumnWind
Bump stops in the front. It should be actually just resting on them, rather than have several inches of space like they are in the rear.
TiGrayMSM
