Delete AFM?
iLikeEggs
Potato!
Oregon, USA
One of the reasons I went with the Superchips was because of the free updates. Easy interface on PC.
992dr
N.C.
Active fuel management or DOD displacement on demand
Short version = Turns your V8 into a 4 cylinder at cruising speed/light loads to help with fuel efficiency.
conchasjim
Thanks. Mine seems to work fine, so why disable it?
992dr
N.C.
Any time :)
They use collapsible lifters which are prone to fail and also consume oil are the two major issues. Which in turn will lead into other issues do to lack of oil.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
I'll tell you one big difference since delete afm. No more vibration when in 4 cyc mode nor awkward exhaust note change when switching from 4 to 8 and vice versa
93blkongreenpro
That's the main reason I disabled it. When I bought the truck, I thought something was wrong with it when on the highway. It seems like a waste, but in the grande scheme of things, it's just another trick to look better on paper.
Just like E85. It looks great on paper bc since you are only using 15% gas, theoretically, you get "better gas mileage" with the gas being used. In real life, for $.20 less a gallon, you get ~30% worse fuel milage.
Combine E85 and AFM on paper, this is a "fuel efficient" vehicle.
conchasjim
Ok, thanks. Mines working fine. No vibration or rough idle or oil consumption. Guess I'll leave it for now.
