2003 yukon denali build
Duramax05blk
NH
going to be updating this once i can get my pics off of my phone. Its been along slow learning,expensive, fun process. The truck lost head gaskets a long while back.
http://www.tahoeyukonforum.com/threads/head-gaskets.59448/
So the wife got a replacement vehicle and I have been redoing this truck as project but its finally nearing completion.
To start it obviously started as a 2003 yukon denali. It is now a 2500hd swapped denali as the denali clip went on my dmax. i refreshed the top end gaskets, rebuilt trans with a trans go full valve bod upgrade, e fans, coil overs with Qa1 all around, all poly urethane bushing/body mounts. a zone 3 inch body was stacked on top. the denali bumper was rotted inside so i went to a roll pan and custom hidden hitch. custom heim joint trailing arms similar to spohn with matching panhard bar. jk (?) cant excatly recall sway bar links. gm brake lines, new fuel lines, full interior sound deading. Magnaflow high flow cats with brola xr1. all stainless steel ptfe braided trans lines and oil cooler lines with custom adapters to stock radiator new trans cooler. mini h1 7.0 retro headlights and all morimoto led lighting. new inner outter rockers, wheel well archs and quarters. pics to come soon....
TheAutumnWind
Very interesting build. Looking forward to seeing more of this rig.
D
Duramax05blk
NH
I am by no means an expert welder but should be plenty for what this truck is capable of towing and will ever tow. i also added braces that tie the back of hitch to frame on both sides.
Probably wont have more updates till monday as most pics are on my work computer now
961.jpeg PART_1435353044220_PART_1435353042089_.IMG_20150626_171001.jpg 20150628_164339.jpg 20150628_164358.jpg PART_1436573545405_.IMG_20150710_201147.jpg
D
Duramax05blk
NH
Got a little ambition tonight and decided to start the next mod.. probably the first Tahoe, Yukon to have "sled stops" still need to be finished probably shorten them and at least 45 and cap the tops
d8162e2ea1a3c1df6a43846a9c87b06b.jpg54279b98dd313d99d11c5608f9718c91.jpg863e3f327e2ed55c07574c469f03e365.jpg1fcfa6c2d0a169405587f0a3ba39f0df.jpg
Sent from my SM-G900V using Tapatalk
D
Duramax05blk
NH
Had to modify pin to fit around frame
I used 1.5 so had to modify it to fit receiver properly still need to shim left to right a bit. And complete other side
cafc41000fb0f664cf8d81dee3832f54.jpg69a75d539a299e405b3938e32f4cd325.jpg100d737fa110e317f5b8d8c9d5af1704.jpg
D
Duramax05blk
NH
Pulled truck out and definitely need to shorten the stop 25bc58cf20a95725a905b2ecdbf7188e.jpg
rick9667
