Wind noise by drivers door
2005SnowKon
Fort Collins, CO
At higher speeds im getting a wind leak on the top of the drivers door. What would work to fix this issue. On a windy day it gets really annoying going down the highway at 75-80 mph
The 'ER
Minnesnowta
My 02 Tahoe does the same thing. I tried to mess with it but now just turn up the radio. Its not leaking so unless someone has an easy fix I am going to leave it.
chauncey0337
MLT, WA
Check the door seals and make sure they're not torn or loose. Also check the top of the window track to make sure there's nothing in there to prevent the window from going all the way up.
2000Yukon
Nebraska
Had a similar problem, just roll the window and tug on the top of the door frame to bend it in a bit.
LOUDHOE
Seneca, South Carolina
Roll down the window, sitting in your seat with the door open, put your feet on the door panel and pull on the top of the door frame...you may have to get mean with it.
