hello - hoping I can get a little help on an issue I've run into recently. I have an '05 Yukon 4wd. (2.5 lift keys in the front, Z71 springs in the back) Recently had pitman and idler arms replaced (both sides) and a wheel bearing on the passenger side. Shortly after getting it back from the shop i noticed my turning radius is terrible and I get tire squeal on sharp turns on certain surfaces. Additionally when backing up sharply I'm leaving tire tread on the pavement. (I can visibly see the path the tires took)
The shop that did the work seemed clueless, I got a second opinion and was told my toe-in was off and got another alignment which helped some but still having issues.
I'm at a loss and hoping someone has had a similar problem and figured out how to solve the mystery.
Any help would be greatly appreciated.
