Painting lower bumper plastic
tyet
Has anyone painted the lower bumper plastic? Im debating doing this on my 2025 HC when i swap the chrome trim to black.
KMeloney
Not I.
Why are you considering doing this? I can't imagine the prep it would take to sand the plastic to a smooth finish and to get paint to stick and be durable.
Stbentoak
I'm not painting the lower bumper itself, but I am removing the Vader Chrome and having it painted black on my incoming 25. Starting to see/hear reports that the Vader Chrome is not holding up well on the front or rear of the vehicle. Just to want to eliminate this right out of the box and get it painted correctly, plus I like the blackout look.....
ReaperHWK
If it was me on a nice new truck like that, I’d talk to a reputable body shop and have them prep and spray it in a booth with the exact paint code. Couldn’t be more than a few $100 bucks.
Save the DIY rattle can paint jobs for the beaters like mine lol
OR
Talk to a wrap shop and have it wrapped. May look good with matte black.
CMoore711
I don’t know…. Unless you’re also going to paint your plastic side steps and the bottom plastic of your front bumper I wouldn’t do it.
If you paint the lower plastic on your rear bumper cover and leave the side steps and lower front bumper alone the rear will “appear” lower than the sides and front. This is because the paint stops and plastic trim starts at about the same line around the bottom of the vehicle. But that’s just my .02.
T
tyet
Why im considering, it looks cheap having the plastic, especially on the high country trim. And yes i would have it professionally done.
Yes I would be looking to have the front bumper and rear bumper plastics painted. I do have the fold down side steps, but it is a concern of mine if those will look completely off.
As for painting that chrome piece, I would absolutely not do that everybody shop I've spoken to has told me it will chip and flake. i've blacked out every single item on this vehicle using OEM parts. You would be better off using that lower trim piece from the RST. here all the part numbers to black everything out.
84496227 bezel
84496193 (S)COVER
13526766 (S)HANDLE
85590194 MOLDING
85590195 MOLDING
84844389 MOLDING
84844390 MOLDING
85649797 RAIL
85649798 RAIL
85136434 MOLDING
85136435 MOLDING
84977518 F FASCIA
86545889 R FASCIA
85775020 Grill
CMoore711
You could purchase those silver bumper trim pieces brand new and get a big enough plastic storage bin as a container and soak them in muriatic acid and it would strip off the silver/chrome coating and leave you with a bare plastic piece ready to prep and paint.
If you’re going to spend the coin to have these pieces professionally prepped and paint matched might as well spend the money to get them wrapped in some paint protection film.
Cause if you’re matte plastic trim looks like this imagine how much more obvious this would be if painted to gloss black to match.
I’m not trying to discourage you here; I’ve done chrome deletes with either painted to match or gloss black with all OEM parts on (2) K2XX SUVS and now on my GMT900.
If you’re using OEM parts then do it once and do it right.
You want to redo it better the second time; That’s what vinyl is for.
T
tyet
As I mentioned, ive already replaced all
the chrome parts with the oem black parts. There is no chrome on the vehicle anymore. For anyone looking to do it, its about $2000 in parts (the grill is the most expensive at $511).
I shouldve also mentioned the whole front of the vehicle is already ppf'd. So yes if i painted the parts in question i would ppf them. The marks on the black plastic under the front bumper is actually dirt, not scrapes, but yes even if ppf'd there is the risk of scraping that area .
Bsto321
I just paint matched all chrome. The only pieces I didn’t paint was the lower piece on front bumper and top chrome on rear hatch. It turned out great and am overall happy with the results.
Bsto321
Tinman265
I do believe all the lower trim is painted a gloss black on the Escalade. A good body shop will know how to prep and spray the parts to last. Personally I'd stay away from a notional churn and burn accident repair shop.
Bsto321
Pics of the work I had done.
Legsinspector
84496227 bezel
84496193 (S)COVER
13526766 (S)HANDLE
85590194 MOLDING
85590195 MOLDING
84844389 MOLDING
84844390 MOLDING
85649797 RAIL
85649798 RAIL
85136434 MOLDING
85136435 MOLDING
84977518 F FASCIA
86545889 R FASCIA
85775020 Grill
I painted the smoked chrome on the back of the car and used cerakote trim stuff on the plastic trim all around the vehicle. And completely changed the front grill. Bought the black and red emblem and badging on Amazon. I tried to load pics, but it says file too large. Oh well. Painted parts are still painted.
NELLY1947
1948Buickroadie
