My 2007 Tahoe Stereo install 18" DC audio sub!
RickyFriery97
Figured id post up some of my work
im mainly into car audio and im very active over on SMD forum (over 1k posts)
First heres a pic of my truck
2007 NNBS Chevy Tahoe LT3
Interior
First mod was 12K HIDs lows and fogs
The other chevy is my 1997 suburban on 22s
ill get that one up later
Blacked out front and back emblem
Got a Pioneer AVH-P4300DVD to replace the stock radio
Since i have Bose and On-star i had to get the PAC OS-4 wiring harness
also got the steering wheel control module
Stock radio
this trim peice was a pain to get off!
Stock radio out
Installed!!
Switch for video bypass
http://www.youtube.com/watch?v=QNqtC8M_Sko&feature=player_embedded
R
RickyFriery97
Ok here comes the electrical up grades!!
Stock batt
resting Voltage before big three
Engine ground
Alt with 1/0
Alt Charge Line
Made a hole for the 1/0 to run through the engine cover
D3400 With I-bar kit waiting to be installed :)
One Ground to the firewall for the D3400
Nice Clean Frame Gound For The Second Ground For The D3400
D3400 Wired in :)
---------- Post added at 12:44 PM ---------- Previous post was at 12:42 PM ----------
Got a nice clean frame ground in the rear
Running the 1/0
Power and ground under the rear seat nice and clean :)
---------- Post added at 12:45 PM ---------- Previous post was at 12:44 PM ----------
Knukonceptz RCAs for my sub amp
R
RickyFriery97
Kicker fuse holder with 300 amp fuse on the 1/0 power run to the back
Box Build
heres the design
6.57 cubes after all disp
tuned at 33-34hz
116 square inches of port
box is for 1 DC audio XL 18" powered by a Audioque 2200D at .7 ohm
1" dowel rod for bracing
Amp rack/false floor
Nice....where did you learn to do these installs?? This is something I'd like to eventually teach myself :)
R
RickyFriery97
when i was 16 my buddy taught me how to install a radio
i guess you can say i was bit by the 12v bug cause ive been hooked ever since
ive mainly taught my self by just trying
also the internet is a huge help
over on SMD forun its aton of nice people always willing to help
its very easy once you get into it
if you ever start on a project like this you can message me if you need any help im always happy to help with this kind of stuff
---------- Post added at 01:32 PM ---------- Previous post was at 01:30 PM ----------
Looks nice and clean!
thanks! that what i was going for
once the box goes in and the seats are folded up you will see no wire whatso ever
you will only hear that 18" bangin on 2200wRMS of clean unclipped power in a efficent box :)
---------- Post added at 01:34 PM ---------- Previous post was at 01:32 PM ----------
welcome to the site.
Thanks!
Brandon X
Michigan
That's great work. I got 2 DC Audio level 2 15's in a 4th order in the back of my Tahoe. I love DC Audio, they make great shit.
AMG ETR
Looks good so far, but just so you know, with the Pioneer unit you can just use a simple relay for video bypass, there is no need for a switch... I can post the instructions when I am at work on Monday if you'd like...
R
RickyFriery97
Hell yea this is my first DC product but hoping to get some of there new amps soon
---------- Post added at 03:11 PM ---------- Previous post was at 03:09 PM ----------
I know this.. I tried with a relay and It did not work for me so I just did a switch
I had it wired correctly the relay just clicked on too quick
B.G.
looking forward to seeing the finished product. This things going to be a beast!
Jbird
last i heard you could use a relay on newer pioneers?
i tried using that steering wheel control module on my buddies truck. Couldnt ever get it to program
R
RickyFriery97
you can.. the relay i had didnt work for me and i had a switch layin around so i just used that
the steering wheel controls were pretty easy, just took some paitence lol
carcrz
Georgia
all looks good, but why are you using ply wood for the box? i thought you had to use mdf board for the box and did you use a grommet for that power wire thru the floor board?
just wandering i might be wrong
R
RickyFriery97
its is not plywood it is 3/4" birch
stronger, and lighter but its also $44 a sheet
alot better then MDF when it comes to boxes
Yes, there is a grommet for the power and ground
Bob LaFord
