Most often stolen SUVs and trucks
strokinpower
The 6.0 is a fantastic motor once bulletproofed. My brother in law has two that pull 38' goosenecks nationwide with over 200k miles and run and pull great. Just got to take care of them.
Gzes
the drifting 2dr
Wichita tx
I refuse to buy a diesel ford. Unless its a 7.3 anything else is not worth the trouble. Looking for a cummins or duramax to get then drop my tow bed on and put to work towing cars. I will admit you can get fords cheaper but also when its tike to sell it will stay forever. Hell i got the exploder last year for a quick flip and still here...
strokinpower
Can't go wrong with a dodge/cummins other than the truck itself is kinda cheap and falls apart pretty quick. Transmissions aren't any good either unless you get a 6 speed. With the duramax the Lb7's have a lot of injector problems and Lly's have an overheating when towing problem they all have problems.
S
Sheriff
People shouldn't have to bulletproof an engine in a new $50,000+ Ford truck or Excursion.
Would you expect to bulletproof an engine in a new $50,000 to $95,000 Tahoe/Suburban/Yukon/Denali/Escalade? :banghead:
yates ™
Resident Apple hater
Iowa
The point isn't whether you should or shouldn't have to but rather that they are good afterwards.
strokinpower
Yea and the motor in my tahoe is burning oil like a son of a ***** so.... and all the people that bought those lb7's shouldn't have to replace the injectors all the time and all the people that buy dodges shouldn't have to replace the transmission all the time..... just look at how many 6.0's and powerstokes in general there are running around, from tow trucks to ambulances to cherry pickers. You hardly ever see a duramax in any of those, around here anyway. I'm done with this anyway y'all like what you like and I like what I like thats the great thing about America!
yates ™
Iowa
The reason you do not see as many GM ambulances is due to GM not producing 4500 or 5500 chassis after 2009.
TowGMC
Wheaton, IL
If you want to know what the professional haulers think, look at what the majority of them are using. Since the majority of trailers are manufactured in the Elkhart IN area I get to see the new trailers being hauled out to all points across the country. By a huge margin the most popular truck is a 3/4 ton or 1 ton Dodge Cummins. The next most often seen on the road are the early decade 7.3 Powerstroke Fords. At the bottom of the list are GM trucks.
I asked the owner of the company that made my trailer (nice guy, loves building trailers, delivers 50+ trailers a week from 20' enclosed to 48' stacker trailers), and he said the pro haulers that deliver his trailers love the Dodge for the bulletproof nature of the Cummins engines, especially the 5.9L engines from '01 to '05. Yea, eventually they all develop rust but never leave them stranded. Even with 300,000+ miles on them. The Ford 7.3 engines are well respected too but don't have the durability of the Cummins. Not a single one would touch a Ford 6.0 even if it were given to them free because of all the problems. The early decade Duramax engines all need injectors by 100,000 miles and that's a $3500 repair bill. And the LB7 engines (02 to early '05 I believe) all require cooling system mods to pull heavy loads.
A friend of my inlaws (in northern Indiana) has several trucks that contract for hauling race and motor home trailers all over North America out of Elkhart. Every one is a Dodge Cummins with manual trans. He bought a new 2013 Ford 3/4 ton with the 6.7 Powerstroke with 400 hp and 800 lb-ft for himself as a daily driver just to see how it would hold up and is quite pleased with it so far. And ordered a 2014 Dodge 1 ton duallie with the new Cummins that makes 850 lb-ft of torque to replace one of his older Cummins trucks that hit 300,000 miles and is just rusting away. His only interest in any GM truck would be the Allison trans.
So not my opinion but the opinion of those who make a living by hauling- the Dodge/Cummins/manual trans is the most durable truck.
strokinpower
The only reason I counted the dodges out when I bought my truck was because until now they never made a full size crew cab. Their crew cab up until this current body style was just a little bigger than the others extended cab. That and the 6.4 powerstroke can make close to 600 HP with just and intake tuner and exhaust. My next truck will probably be a Dodge 2500 with the cummins just to try something different.
strokinpower
Those are awesome I've always wanted a 2500 suburban even with a 454 or a 6.5. I just watched that video again and that is one sexy suburban!
Gzes
the drifting 2dr
Wichita tx
Everyone running tow trucks and whatnot run cummins or duramax have yet to see a ford powerjoke. Like i said i dont like em would only touch a 7.3 if cheap enough and was in top notch condition. Ambulances are ford because fords the only ones that make a van that big. That and the rear end is usually gonna be the dana 60. Gonna use a ford e van dana 60 rear for my hoe when i do sas because its a dana 60 and its rear disk
strokinpower
I have honestly not seen a duramax tow truck in years and the rear end is a dana 80 if it's dual rear wheels.
Stresst
You know why all those trucks are on there??? Because for some reason if a truck has something stolen out of the back of it it counts the same as the whole vehicle got stolen for these studies.
Bingo! :Handshake:
---------- Post added at 10:13 PM ---------- Previous post was at 10:09 PM ----------
Yup
I drive a Ford too and have had dodge vehicles as well and never had a problem with them.
Sent from my iPhone 4g using Tapatalk
I dont know why people bash Ford??? I have had several mustangs, E350 work vans, F250's, Lincoln LSC's, Navigators and they were more reliable then the two Esky's and Denali that I recently owned. Again not sure why ford gets a bad wrap:mad:
Gzes
the drifting 2dr
Wichita tx
Because they are built with vey cheap parts. One ****** is the 02-05 ford exploder. The back hatch cracks in the cold because of cheap material. They have been sued for years on it and yet they refuse to repair. Shift solenoids go bad and again no replacements from ford. Heres a better case. Dash cracks in newer gm and gm replaces it and almost always eats the cost.
strokinpower
Chevy's are built with cheap parts too and so are dodges... that's why my dash is cracked in my tahoe (and they DO NOT replace it and eat the cost I don't know where you got that load of crap) and all the paint wore off the climate control buttons and the finish wore off the steering wheel trim and the active fual management causes the engine to burn excessive amounts of oil and so on and so forth, some people are on the 3rd and 4th dashes in gmt900 series trucks. Here is some reading on the dashes if you care to poke around... http://chevroletforum.com/forum/tahoe-suburban-25/2007-tahoe-ltz-dash-has-cracked-26133/
yates ™
Iowa
As usual you have no idea what you are talking about. :nono:
Vortecmass
Red colors are the most stolen vehicles too, not matter what make or type these are. Wonder why auto insurance cost more?
moto
