Help needed. Wiring on senor next to starter ripped out.
nawagner
I have 2004 Yukon XL and when I was changing the starter I somehow pulled all the wires out of the sensor mounted to the block next to the starter.
Number one, what is the sensor next to the starter?
Number two, does anyone know what the positions of the wire colors are in the connector?
I've looked for a wiring diagram but can't find what I need.
Thanks in advance!
N
nawagner
Fixed it. For future reference to anyone searching for this same problem.
It is the Crankshaft Position (CKP) Sensor.
Pin-out and wiring diagram found here:
http://67-72chevytrucks.com/vboard/showthread.php?t=383692
Would highly recommend that when you change the starter you disconnect the CKP connector once the starter if free and hook it back up after the new starter is in.
Durobans
