EGR Valve / Plugs
smyers33
East TN
Well I don't post a lot just read all the useful info this site has. But today I went to Auto Zone to see why my check engine light kept coming on every now and then, and they said it was my EGR Valve, and that I had a misfire on cylinder 4. So I bought the EGR Valve and replaced it, and new plugs to put in. I put the valve in no problems but it got dark before I got time to put the plugs in.
I did the seafoam in the Brake Vacuum line before I went to Auto Zone, so do you think it was the seafoam that fouled one of my plugs? Or do I just need a tune up due to the high mileage 145,000?
Any advice would be appreciated. Thanks
haks310
Got LEDs?
SoCal
Usually I do a full tune up around 100K miles. Cap and rotor, plugs and spark plug wires. Did you try cleaning the EGR valve before you bought the new one? What years truck?
smyers33
smyers33
East TN
No I didn't try cleaning it. I didn't know anything about them until after I installed it. The old one does look pretty nasty in the two holes though. And it's a 1999.
Bad bow tie
Grizz Straight FTMFW
Michigan/NC
I've never heard of Sea Foam fouling the plugs but I don't know. I ran sea foam two or three times and just last month changed the plugs, wires, cap, rotor, and TPS sensor. The plugs were not fouled from the times I sea foamed it. I would still do the tune up, unless you've done one recently. But you should also do the wires, cap, and rotor while you're at it, not just the plugs. I recommend AC Delco, I seem to have the best luck with them. Accel wires are junk, I have had problems with them in the past.
OKLAGMCRUISER
Need drop...send $
Kiefer, OK
i seafoamed my 99 nbs twice and both times fouled the plugs and had to replace them! Codes went away and rough idle was gone after plug replacement!
AtomicHoe094
Atomichoe094
cleveland, OH
+1!! mine never fouled, but it is a common thing to happen. If your motor is super dirty when the seafoam is working it in there, a lot of that dirty moves around and well sticks to your plugs and such. i would strongly recommend doing a tune up after it, if you know your truck was super dirty.. After the tuneups done, it will probably feel like nite and day.. You can clean your old egr if you wanted to with some carb cleaner.. Mine was bad before seafoam and i heard that they usually get killed with junk so i replaced it after seafoam :)
haks310
Got LEDs?
SoCal
Oh okay, well you already have the new installed so no point in taking it back. Just go ahead and do a full tune up and you should be fine: Cap & rotor, plugs and new wires.
smyers33
smyers33
East TN
No seafoam in the oil, just gas tank, and vacuum line. But thanks for all the replies. I called and got an appointment for friday morning for a tune up. New plugs, wire, rotor, cap, air filter, and fuel filter and labor for $180. Very decent price in my opinion. But I'll post good news hopefully tomorrow afternoon. Thanks again!
ravingmadman
Chief Knuckle Buster
Greater Seattle
Wow, that's really, really good, if they actually do it for that. You have it in writing, I presume?
haks310
Got LEDs?
SoCal
Wow, are you sure that is including labor? Parts alone would be that much, and that is using the cheaper stuff.
AtomicHoe094
Atomichoe094
cleveland, OH
haha you should permanent marker everything on your car with a big red x and then after the "tune up" go back and look at everything to actually see if its been changed.. alot of shops will say they do something but actually dont..
smyers33
smyers33
East TN
Welp just got it back. They hooked it up to the code reader and everything is gone now. Very pleasant experience I walked in the door and he said it would be $167 after tax. I told him that couldn't be right but they never replaced the air filter because I had just put one in a thousand miles ago. I'm happy and everything is fixed for 167 bucks.
Bad bow tie
Michigan/NC
Yeah, Yeah, what all did they do to it for $167? If you got it completley tuned up for that price, that's awesome. I spent over that on my parts to do mine last month, and I did it myself.
haks310
Got LEDs?
SoCal
smyers33
smyers33
East TN
i'm not sure what parts they used, but even if I did I wouldn't know if they were a good brand or a ************* brand. I'm just not up to date on that kind of stuff. But here's what it says on the receipt. TTW Wire Set $16.92 OSS. Fuel Filter $7.99 TT. Dist. Cap $30.03 TT. Rotor Button $7.78
qlc1964
qlc1964
them wires must not be lifetime wires for that price you can't buy no wires for
that price. but were glad you got your must needed tune up.
briannorris
