Anyone used the HD tie-rod sleeves from RC
owl_93
I was thinking about beefing up my tie rods with the sleeves from Rough Country. For $35 I thought it'd be worthwhile. Has anyone tried these out? Someone with an '01 Tahoe gave them a good review but that could always be faked you never know.
http://www.roughcountry.com/gm-tie-rod-sleeves-1144.html
Sent from my Galaxy Note 4 via Tapatalk for Android
jough
Arkansas
I have them...still in the box. I'll install them some time this year. I don't think they would tighten up the steering, just make it harder to bend a tie rod if you hit something.
yates ™
Resident Apple hater
Iowa
Kinda what jough but their main purpose is to help strengthen the tie rods when running larger tires as the tie rods are usually the weak point. For you I would say they're not needed but wouldn't hurt to have them.
TheAutumnWind
Interesting. If you wheel it hard then yeah I could see that upgrade making sense.
owl_93
owl_93
Yeah, my tie-rods just have 15 years of use on them and I do wheel and I wouldn't want one stupid mistake or rookie approach line cause me to break a tie rod out on the trails. That would really be a shit-show. I just want a little more peace of mind and have one less thing to worry about
TheAutumnWind
Did youend up installi g them?
Bringthis thread back from the grave!
Im doing tie rods atm and curious... I know they dont work with moog inners unless partly drilled out... Which i could do with my drill press
owl_93
owl_93
Nah I never ended up doing them. I'm waiting to do a whole front end overhaul with coil overs, longer UCA's, new CV's, and a slight front diff drop to keep my CV angle from being so miserable. Waiting to get my savings account back up from bein unemployed the last few months.
M1Gunner
Gainesville, Fl
Just watch that front prop shaft angle when ya drop the front diff.
owl_93
owl_93
Im looking to find a happy medium between drive shaft angle and CV angle. The drive shaft is stil lstock angle and can go down a bit which wouldnt hurt it but would provide a hell of a lot of relief for the CV's. Need to find an optimal compromise and then a good way to drop it. Any suggestions? Probably need to have a custom bracket fabricated.
TheAutumnWind
Nobody makes diff drop spacers?
owl_93
owl_93
I've seen some but none the right size so far. One option is to buy some larger than I need and put them on a disk sander and keep them all in check with a digital caliper
Sent from my SM-N920T using Tapatalk
Korbin_A
