97 2 dr tahoe ac not working
ygrbom
alright so my ac doesnt work the compressor is not getting power wondering why its not getting power fuse was good and changed the relay wondering if you guys have any idea? thank you
gpracer1
Phoenix
There could be 10 things wrong with it.
Start with all the fuses (easiest)
Check freon pressure with gauges.
Go from there.
Y
ygrbom
fuses are good and its pressurized on the low end
SunlitComet
OBS Jedi-Do Good
unknown at this time.
how may lbs. if you can tell? Also disconnect the connector from on top of the freon line into compressor that has a black/white and dark blue wire attached to it. Short the terminals in the connector and try again. If it activates then either that pressure switch is defective or the freon charge is to low still.
CKendrick
