22" factory LTZ wheels black chrome
customlll
Winnipeg
I am planning to install a leveling kit with 2.5"-3" front and 1" rear lift and get my factory 22" Tahoe LTZ wheels powder coated black chrome and use LT285/50R22 Nitto Terra Grapplers. What would be the best leveling kit? And will I have any rubbing issues?
Neil Layne
Steel Neil
Lafayette, Louisiana
those tires are 33.6" tall and 11.6" wide. i have a 2.25" lift in the front and a 1.5" lift in the back with 295/55/20 nitto trail grapplers, which measures out to be 33.25" tall and 12" wide. i did very minor trimming just to the plastic and i don't rub at all. so if you did 2.5 of 3 inch lift in the front and a 1" in the back I'm sure you will be fine. it takes 5 minutes to cut the plastic if you need to. post pictures when you are done. that will look very good.
C
customlll
Winnipeg
Do you have any pics? By raising the vehicle, will this cause any problems with any of the Adaptive Cruise Control or other sensors?
Neil Layne
Steel Neil
I'll try to take some pictures tomorrow. There are several people who have had to do the same thing (trim the plastic)
I've had my lift for 2 years and I haven't had a single problem. What year is your vehicle? I have a 2007, if you have a 2006 or older it is probably a little different. But if not you shouldn't have any problems with any sensors or cruise control.
Neil Layne
Steel Neil
http://www.tahoeyukonforum.com/forum/showthread.php?t=62331
---------- Post added at 11:57 AM ---------- Previous post was at 11:54 AM ----------
this is the thread with the other 2015 yukon lifted. he was able to fit 295/55/20 toyo mts without much rubbing at all. he's got a 2.5/1.5" lift. i hope this helps because it is the only thing i can find to help you out. i don't know much of anything about the new models.
---------- Post added at 12:05 PM ---------- Previous post was at 11:57 AM ----------
if you are going for a 33" tire, i would get the 305/45/22. i just did a little research and that comes out to be 33.2" tall and 12.45" wide. the terra grapplers look good on 22s also. thats probably the biggest you will be able to fit with that lift without much rubbing at all. but again, i don't know too much about 2015s
Tahoer2008
