Additive Spill
A10MileHusker
Beaverton, OR
I went to add some HotShots EDT before a fill-up, and put it in the tank, and then saw that it was coming out from under the truck.
Does anyone know what I'm doing wrong? Is there an overflow I need to get past? I was just using the additive bottle to add it.
Thanks!
2024 White Tahoe
Thanks!
Was the bottle designed to be used with a cap-less fuel fill?
Did your vehicle come with the the cap-less fuel fill?
Hey you
That is what it sounds like. You can improvise with a funnel and some rubberized tubing.
Stbentoak
Yes, Or Transmission funnel. Most of my vehicles had a funnel included for additives or big rig nozzle adaptation in an emergency.
Never have needed one for def as the Walmart nozzle goes right down in the hole as well as any DEF pump nozzle.
Hey you
Where is this vehicle funnel stored... I have looked and not found anything.
2024 White Tahoe
When I purchased my Tahoe new, the GM funnel was inside the rear storage compartment.
You can buy the special funnel at most auto parts stores.
Towmaster
