Morimoto XB Headlights Installed
Loki223
Elk, WA
Well figured i'd share this in the exterior section even though i posted it in my ramblings thread about my burb. But this past weekend i installed a set of Morimoto XB headlights. if i had been thinking, i would've taken some before pics, but let's face it, we all know how the stock headlights perform. And let me tell you, first impressions, WOW. So much better and cleaner light then stock. To install them, you do have to pull the bumper, Morimoto has a nice video showing how to do that, it's not to hard, but it does extend the time frame on how long this take. In terms of wiring, EASY. You drop a fuse tap into #75 under the hood, and run the wire to your housings. That's the only added step. One you've gotten that far, you get to start plugging in the new lights. They use the factory plug, no adapter harness, or canbus boxes or resistor boxes, nothing. Just plug in the headlights like they were stock. That will get you to this point (and might as well put a light bar behind the grill while you are there
From there, you put everything back together and get to this , and man. do they look good
And once you've done that, you get to wait until it's dark to aim the headlights at 25 feet. and just really appreciate the clean beam pattern they give you. Adjustment is done from the top with a phillips screw driver. Nice and easy, from the factory both were aimed very high I'll be doing some gues and check measurements since i don't have a good option for flat land with a wall 25 feet away at my house. But i'm pretty sure i got them pretty close. I'll fine tune them over the weekend when the burb gets driven the most.
Then you get to appreciate the perfect amount of fog out for some good glamor shots
But what you really want, is some use pics. These are going down my driveway
Low beams
High beams
Lighting is amazing as you would expect from Morimoto. I'll link where i got them, they usually have a way to save 5% or more off the listed price, and lets face it, in this economy every penny matters I'll also try and get the wife to help make a video, i have one, but i didn't get the startup sequence which is kind of neat to watch. Overall impressions, 10 out of 10. I might be biased since i've had the XB housings on my truck for a couple years, but i love the quality they put out. You just can't beat them
Electrickian
Senior Member
Texas
I'm gonna be totally honest: I've never been a huge fan of the headlights on that generation of Tahoes and Suburbans, but those lights actually look pretty damn good. I'm impressed. Good work bud
MADDOG
Air Force Administrator Moderator Community Manager
Arizona
That's a good look.
I installed the version that fits my Ram 2500 pickup last year and I have been very happy with them.
Loki223
Loki223
Elk, WA
The light output is great and worth it.
That's a good look.
I have those too, honestly if it wasn't for already having a set, i might not have spent the money on the set for the burb, but i am glad i did
mnjeepmale
I installed these on my '15 Tahoe couple months ago. They are amazing. I do get a few cars flashing their lights at me like I have my high beams on. I'll have to look and see if they need to be adjusted.
One thing I do notice, when driving I can see the lights shake a little on road signs when going over small bumps.
Forky
NorCal
How would these compare to a retrofit of upgrading the factory projectors? Like the Morimoto M-LED projectors? I have the factory HIDs (2018 Yukon XL Denali) and moved to the Phillips bulbs but still wish the lights were better
Too_L8T
$1800??????????????????????????????????????????????????????????????????????????????
Loki223
Loki223
Elk, WA
they will exceed the MLED retrofit, mostly due to haivng more LED proejctors in them then the MLED Retrofit would do. a D2S retrofit would be about the only way to exceed the output on these
Yes, things cost money. Nice things cost more money then bad things. this is the way the world works. They used to be cheaper, but yeah, they are quite expensive, and worth it IMHO
Loki223
Loki223
Elk, WA
ok bud got it. thanks for the insight
I'm very insightful. This one time. at sight camp. We used sight glasses to look at each other to confirm we were all in sight.
Like yeah, they are punch me in the crotch expensive. but they are worth it compared to the other options on the market. a D2S conversion might outperform them, and could be done for much cheaper. Also kinda curious about what lights Boost is going to offer, they are releasing more options soon but a little late for my decision making processes. I just knew if i was pulling my housings i wasn't putting factory back in.
CRN_25
