2.5” lift 2023 AT4 Yukon
mcasey5121
Has anyone put the Rough Country 2.5” lift on a 2023 AT4 Yukon? If so, got any pictures? How did it change the ride? Any advice…THanks!
Rayse
I did it to a Denali with mag ride. Didn’t change the ride at all. Still need some tires. My only complaint is the upper control arm is super close to the factory tires so you may need an aftermarket wheel. IMG_7214.jpeg
djnice
Did you install it yourself? If so, how did that go?
I think others are using wheel spacers to deal with the upper control arm issue and fender rub with wider tires.
djnice
Installed RC 2.5 lift on AT4. Will post in mega lift thread. Lifted about 2.5" front and 2" rear.
Goldwing2000
