A/C light Flashes 3 times. No cold air.
Jrschultz
2010 Tahoe LTZ. Had the the A/C charged. Cold air for about a month or so, and the A/C light is back to flashing 3 times and no cold air. Removed cap off A/C line and it still has pressure. Changed the ambient sensor. What else could be my issue? Driving me nuts
You need to get a Tech-2 on this to pull the internal trouble codes. Check the Tech-2 owner's map to see if someone lives nearby. I'm in Florida.
Whats a Tech-2?
If you do any wrenching work on your own vehicles, that as @swathdiver recommended, purchase a Tech 2 (~$350). It will most likely pay for itself the first time that you use it to diagnose an issue. I have saved literally thousands of dollars working with my Tech 2.
agjackson1981
