06 yukon SLT swapping denali headlights?
B_BODY_1
NW IL
Hi I am wanting to make a 06 yukon have the denali headlights...
I would assume the 03-06 (00-06) would have the same mounting set up for the headlights, does anyone know if it is the same?
I am also guessing I would need to change the grill and markers since it has a different layout?
2000Yukon
Nebraska
If your just doing the headlights nothing else needs to be changed. Out with the old and in with the new
B
B_BODY_1
NW IL
Thanks
If I decide to do the denali markers can I just do the grill and its good?
Should I go with used from a yard or is there a good aftermarket set that isn't garbage available?
NeverSatisfied
eBay Baller
Wichita, Kansas
Thanks
Headlights will swap out no problem. To do the marker lights you would need the grill and the bumper to complete that. The grills are different shapes
2000Yukon
Nebraska
I almost forgot to mention, I believe the low beam bulb on the denali lights are a different style and have a different plug.
Not a 100% sure on that though.
TheAutumnWind
My low beams use a 9005 bulb, same as the highs. The plug is slightly different.
Sent from my HTCONE using Tapatalk
cdhpc2
