lowering question
mikeyboy
freeport new york
i bought my tahoe from a guy who didnt no much about it when u bought it it came with 26' rims so i wanted to go lower so i sold them and got 305/40/22 .when i bought the truck the guy said it was lowerd but didnt no how much i want to no how much is in it because with the new tires i want to go lower also as i did my wheel baring last night i noticed that the rear sits on the bump stops so i dont no how i should go lower if i can it never bottoms out and it rides good .. so my questions are ..
what drop do you think is in it ?
how can i go lower?
Modded
That Guy
Most likely if its was lowered when you gt it on 26s then it would be a 2/3 drop. You could go as low as 5/5 with 2" spindles and 3" torsion cranking up front and 5" coils out back.
The bumpstops probably weren't cut to the proper height to match the 2/3 drop and thats probably why it sits on the bumpstops.
Max
Mile High
Denver
Do the free travel mod and you should be able to drop it a good 5" or so out back even with the wide tires. I'd get some spindles for the front and it would sit nice, probably a 4/5 drop for the best ride quality.
NathanJax
Vacation Nathan
Jax, Fl
Max is about 4/5 or so on 20's...
I'm 4/5 on 22's... http://www.tahoeyukonforum.com/forum/showthread.php?t=4728
For the front:
3/4 Ton Keys in Front 1" to 3" Lower
Bilstein HD shocks f4-be5-6500-h0
Eibach Sway Bar
McGaughy's 2" Drop Spindles
For the rear:
Airlift Inner Spring Rear Helper Bags
Bilstein HD shocks f4-be5-6501-h0
Belltech 5" Rear Coil Springs
Belltech Rear Shock Extenders
DJM 3/4" Urethane Rear Bump Stops
DJM Free Travel Mod
Eibach Sway Bar
BOSS
The People's A D M I N
Dallas
how can i go lower?
Instead of posting this like you did in response to someone's previous question on a seperate thread:
duuuuuuuuuhhhhhhhhhh
I will answer your question.
It looks like you have a 2/4 drop. I would check the keys to see if they are aftermarket, and check the rear coils to see if they are stock. Go from there.
BOSS
fatnlowtahoe504
New Orleans, LA / Hattiesburg, MS
yea what they said, its about a 2/4, and yea cut those bump-stops and brackets off, change the coils and see if you can get the t-keys to crank lower...but the truck looks pretty clean! also might want to consider some drop shocks of they arent already on there (or shock extenders for less $)
denalianyone
NYBlackLade08
New York
sorry to see the 26's go..looked much better on those...at the same time I can understand with the streets in NY
Grocery Getter
A guy with a truck.
Phoenix, Az
26's in NYC...... Oh no sir. I spent yesterday driving around Manhattan in a rental car and all I could think of was how quick my Tahoe would be toast. Mad props to boys on big rims in NYC, u must be ballin just to keep up on the repairs. I did see an Esky on 24's while on the LES that had my rims. That makes 2 ppl Ive seen with them since I got them almost 2 yrs ago....
vsaravia
