I think I might have blown something in my transfer case today.
h0tr0d
Brenham, Tx.
I left work and 2 miles away, pulled out onto a road that had a slight up-hill climb and as soon as I gave it a little gas I heard a loud bang, then a high pitch whining.
I pulled over and noticed the LED indicator on the transfer case control was off. I tried pushing the 2hi button and nothing happened. I was eventually able to put it into 4high, then when 2high was pressed, the light didn't come on. It started working when I turned the truck around to go back up to work.
The high pitch whine seems to get better when the speed increases, shifting to a different gear in the transmission doesn't seem to change the noise at low speed.
I thought I'd ask you guys how you would attack a problem like this, as this is my first 4x4 and I've never had a major problem with it before.
h0tr0d
h0tr0d
Brenham, Tx.
do you still have a reverse gear?
I don't think I tried reverse, but otherwise it drives fine...just a whining noise coming from around the transfer case/tranny area. I didn't try to engage 4x4 and drive it after it happened either.
I don't think it's throwing a code, but I'll hook up my reader tomorrow to be sure.
---------- Post added at 05:52 PM ---------- Previous post was at 05:38 PM ----------
Tomorrow I will check reverse and put it up on jackstands with it in gear and get a video of what's going on.
h0tr0d
h0tr0d
Brenham, Tx.
@SunlitComet - You were definitely onto something. I have no reverse gear now. :(
SunlitComet
OBS Jedi-Do Good
unknown at this time.
I believe you have broken your sun shell. I am afraid you need to tear it down to get to it. The more you use it the more damage you will cause. A newer stronger one called the beast is available. Depending on other tranny conditions you may just rebuild it. You will see the bearing, bushings and clutch's condition once torn down. Sorry man.
h0tr0d
h0tr0d
Brenham, Tx.
I believe you have broken your sun shell. I am afraid you tear it down to get to it. The more you use it the more damage you will cause. A newer stronger one called the beast is available.
Thanks for your help man. Sounds like a fun time. :emotions122:
At least I get to try out rebuilding an auto tranny for the first time.
xanatost
Lafayette, La.
I rebuit mine and it realy is not that hard. If it was me I would go ahead and rebuid it. Put in better cluches wile you have it down. You will need one spechal tool and the rest will be normal hand tools. There is a DVD that you can get that will walk you throu it as well. Here is a few sites i looked at before I did mine.
http://www.4l60-e.com/
http://helpwrench.com/forums/showth...uild-Guide-with-Pictures-Tips-Pics-and-Tricks
http://racetransmissions.com/store/product_info.php/products_id/692
http://www.gmhightechperformance.co...60e_automatic_transmission_rebuild/index.html
h0tr0d
h0tr0d
Brenham, Tx.
Thanks xanatost. I'll be crawling under mine as soon as the rain stops here...it's been non-stop for a solid week. After reading all this material and watching some videos, it actually doesn't look as hard as I had imagined in my head.
xanatost
Lafayette, La.
Its realy not that hard. If you are perty handy with tools then you can do it. just take your time and get the DVD so that if you see something you are not 100% about just back up the dvd and watch it again. One thing I would sugest is that when you remove the t55 head screws where the stall converter is at put in grade 8 bolts. I striped mine out when I was rebuilding mine and after talking to a few friends of mine they said it was ok to use them and would be better if you ever have to rebuild it again. Just make sure you get the same size and thread. After you do you will kick your self for not trying it sooner lol. Hell I even rebuit a AX15 5 speed for my jeep just to see how hard it was, it was even easyer!
h0tr0d
h0tr0d
Brenham, Tx.
I've always had manual cars, and in the instances where I needed another automatic, I've actually had a good spare laying around to throw in. This is the first time that's not the case and with money being extremely tight right now, I can't afford to just grab a rebuilt one.
I do have a couple high mileage C6's laying around that could use a minor overhaul after I get done fixing my daily driver. :)
Drewphil
