i know its already been asked
blue99tahoe24
bout that tahoe life
joliet il
i wanna lower my tahoe like one inch or so and some thing was said about torsion keys and whats leveling i have a 1999 tahoe z71 4wd with 24inch f5 rims and i dont like those any more i wanna lower and put some 24 inch irocs on it i think it would look mean would like to know the best way to lower thanks and comments are welcome
foreverfalcon40
Front use your stock keys, 24's will eat up most the gap.
Rear's I say drop shackles bc you can alter the rear stance. You go adjust your shackles in case there is rubbing issuses.
blue99tahoe24
blue99tahoe24
joliet il
is there a post on here that shows how to do it with the stock keys i want to lower because of the big gap between the tire and the fender and i like the stance of the tahoe limited thanks
AtomicHoe094
Atomichoe094
cleveland, OH
Spray some PB blaster or wd40 on those key bolts before you attempt to lower it. this will make it easier.. all you need to do is crank it down instead of up lol
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Follow the long bars from each lower control arms all the way back to the cross-member on the bottom of the cross-member a few inches from the bar you will see a bolt. Only adjust it after taking all the weight of front wheels. Then bounce the front and check side levelness and re adjust if needed. Get an alignment afterwards.
SunlitComet
OBS Jedi-Do Good
Not sure myself you will have to see how far you down you can go. Keep this in mind. The same height left and right will have different amounts of bolt threads showing. So if you bottomed one out on the other side might not be. Which ever key bottoms out first will be you drop limit with out re-keying. You will be turning counterclockwise to lower when looking up.
Gzes
the drifting 2dr
Wichita tx
Y would ou want. To lower a 4x4? What's this world coming to:( I do like lowered 2wd trucks tho it's just not that bright for a 4x4
Gzes
the drifting 2dr
Wichita tx
Well yes it's his truck and ge can do whatever to it but I just think that it defeats the purpus of 4x4 and yea it's good for climbing over the speedbump when you can't get over it without ripping the bumper off and also with the trailer thing any truck can pull a trailer but the lowered suspension will go lower in the back due to the weight on the hitch and if it is too low then say bellow to a shitload of sparks flying all over he place causing a safety hazard. I wasn't saying don't do it I'm just saying that's it's not a good idea for a 4x4
Gzes
the drifting 2dr
Wichita tx
Also couldn't yo just drop the font causing the tuck to look like a muscle car/suv? I don't think it would look bad on it.
blue99tahoe24
blue99tahoe24
joliet il
i dont use the truck for any towing i dont own a boat or trailer so i dont have to worry about that its going to be a show truck and i dont even use the 4wd i keep it in 2wd all the time
blue99tahoe24
blue99tahoe24
joliet il
lol i think i located the key bolts they are like in the middle of the truck??? and if i change to drop spindels will the front tires sit in the wheel well better like the rear tires
Drewphil
