thoughts on 8.1L Vortec vs. 6.6L Duramax
SSmurdered
i know u see me
Pittsburgh, PA
BROTHERS!!! i am still alive, i know you were all concerned.
i am looking at getting a silverado or sierra. its gonna be a crewcab for sure and a HD but im torn between what power plant to choose. gasoline 8.1L or 6.6L diesel???? need some input, pros and cons, any personal experience....whatever!!!
solored
canada
8.1L is not good unless your going to tow, very little aftermarket mod support
baron
I want a power house! Something to get a programmer, exhaust and intake on.
Then you want the Duramax. A programmer isn't going to have nearly as much impact on a naturally aspirated engine as it would where there is a turbo involved. Generally speaking, the same is true on the exhaust and intake. Both will realize more performance gains when you are looking at forced air engines. For instance, for under 600 bucks, with a ATS programmer, on a 2007 Duramax 6.6, you are looking at these increases over stock power with each level you turn it up:
1. +50hp - +97 lb.ft.
2. +90hp - +160 lb.ft.
3. +120hp - +200 lb.ft.
4. +180hp - +265 lb.ft.
5. +221hp - +332 lb.ft.
6. +270hp - + 349 lb.ft
SSmurdered
SSmurdered
i know u see me
Pittsburgh, PA
That stage 6 is ridiculous! Now im swingin duramax but im gonna get a used truck. I see some with 250000 miles.... should i be turned away from high miles on the diesel? Wats there to look for like notorious problems with duramax with allision tranny??
baron
I'd be a little weary of turning the power up to the top stages on a truck with that many miles, but I must say I'm not an expert on the HD line or the Allison's. From anecdotal evidence, I'd say that as long as they have been maintained well, they should still be pretty solid (from the engine perspective) with that many miles. I'd do a bit of research on it though. Just from a general wear and tear thing though, diesels usually outlast their gas counterparts. Part of the reason is you get a some extra lubrication on engine components through the diesel itself. Not as much as you used to with the ultra low sulfur stuff they use now, but still, not as bad as gas.
AquinoSteven
Key and Spacer Guru
Clinton, NJ
Dont settle for the first one you see. Have someone go with you that know diesels a little better or even bring one home for the day to check it out. Here a link to the duramax wiki page. It explains each motor year and the pros/cons of each one.
http://en.wikipedia.org/wiki/Duramax_V8_engine
Now that i see your area, me and a friend run a high performance diesel shop out here in NJ about 20 min from easton. We are looking to start purchasing trucks to fix up and sell. Im sure one of us could head out to an auction one day to find a good truck for you. We would have no problem getting all your additional parts lined up for your too. Send me a PM if you want more info
str8wkd
De.
pre 2004 1/2 has internal injectors witch has known problems there is a updated version for it rods can handle up to about 500 crank hp before stuff gets harry 2004.5 has good injectors but still has same rods with I think weaker piston but can still handle sam power 06 or 07 has a motor know as a detuned version,
engine codes are lb7 for shity injectors lly for good ones (creaturesofthenightperformance.com) the guy that runs the site can help better if yiu need it
hoe
did not read this thread... but you got to be kidding me... Duramax is so much more of a engine, its not even comparable.
AquinoSteven
Key and Spacer Guru
Clinton, NJ
Big duramax fans all know that the best years that GM produced the DMax was from 06-07.5. No emission crap and 360hp 650lbft. IF you look at the vin, look at the 8th numeral, if it is a D, then youll have an LBZ. You also get the new 6 speed allison.
Diggerdan11
The State of Jefferson
:signs75:
yeah the 06 DMAX is awesome and the 6 Speed Allison is really neet. I would not even think about getting a pre 06 DMAX, now the 2011 DMAX has even more power and torque but yeah I have heard it has a bunch more emmisions crap.
Once I pay off my SS I am thinking about getting a DMAX and it has to be an 06 or 07classic. I dont like the newest body style as much. My Dads 06 DMAX is such a beast and he gets much better Gas mileage than my SS or Hoe
And as for the 8.1 its is an ok engine, the only thing it has going for it is its 455 Ft/lbs of torque, which is good for a gas engine. But My mom had the 8.1 in a Suburban and it sucked gas like crazy, plus there are hardly any performance upgrades.
I say go with a DMAX (Even a 01-05 would be ok but not as good as an 06+) but if you want gas just go with the 6.0, there are lots of performance upgrades and you could have it produce much more power/torque than the 8.1 and get better fuel econemy
Bwaldron
