Electronic Limited Slip Differential activation
CCPLuvr
All.
I spent some time looking through the owner's manual and what I could find online without an answer. I did see that the owner's manual said Terrain mode uses eLSD but no other mode mentions it's use. What activates the eLSD in our vehicles equipped with this feature? Is it always trying to detect slip then activates or is it only in specific modes?
Hobert
Downers Grove, IL
I believe it's automatically engaged. Kind of like the old G80. Here is a good description although it is the corvette's eLSD.
C
CCPLuvr
I understand how it functions, that's one of the reasons for wanting the air suspension package. But GM only references it in Terrain mode in the owner's manual. How do you know it's active all the time? I find it odd that's the only mode it's referenced in. I hope it's not the case but if it is I'll truly be disappointed.
C
CCPLuvr
Here's an interesting video showing the eLSD engaging in 4LO. From this, and at least this mode, I'd say it's not engaged all the time.
well couple things, the system operated "as designed" in that video
the tires were not great for that terrain, but with increased speed it would make it through what they showed with no real problems
the 3rd thing is not many people are going to go spend $100k+ on this vehicle and then go out and do what they are doing, because it is going to get damaged either by poor ground clearance or trees and bushes scratching the hell out of it.
In some cases the electronics are not doing you any favors at all
WalleyeMikeIII
Sunny and Snowy Minnesota
Perhaps you need to better explain what you mean by "engaged all the time."
The differential is not locked all the time, as this would defeat the purpose of having an eLSD.
I do believe it is "enabled" all the time, meaning: electronics constantly monitoring for wheel slip, and if that occurs, engaging so that it vectors the torque to the rear wheel that has traction and away from the one that does not.
homesick
The Best Me I Can Be
Navy Air Force
... In some cases the electronics are not doing you any favors at all
That's no joke. There's way too much Nanny built into cars.
I want to control my own headlights, my own wipers, my own a/c controls, etc. And this is the small-time stuff. Now we can add auto braking and auto forward space cushion.
They've even automated the crashes.
joe
Marky Dissod
Sounds like pedantic minutiae, but there is a critical difference between
enabled all the time
and
active all the time.
It's like how some people carelessly confuse the words 'disable' and 'delete'.
It's always enabled all the time, but I've yet to suffer priapism ...
C
CCPLuvr
I would expect in a couple modes that the differential would be engaged until there's a significant wheel speed difference. It takes quite a bit of wheel spin before it engages.
C
CCPLuvr
My hopes were more than how the system was designed. We're planning on using ours for some off roading this year, significantly more than the what they did in this video. Wish GMC offered an AT4X version of the Yukon, I would have been all in.
the way gm has these setup it is on demand only, there is no "full time" mode, for that you would have to go aftermarket if there is even anything available. Not too many off-road company's offer a line for gm suv's. you see this more for the small pickup line (Colorado/Canyon) and Silverado/Sierra.
If you are planning on taking it off-road like they did in the video or even more extreme, set aside money for a paint job afterwards
the paint is paper thin on these and you will have battle scars guaranteed.
I paid $27k for my silverado 4x4 hi/lo, lifted it 4.5", put on 33" tires, added air suspension in the rear that gives me about another 4" of adjustable body lift, added a winch, d-rings,
I have a variety of equipment to self-extract if needed
and she gets battle scars pretty easily still, some of this may buff out but no point at this time. it is what it is...
I sure wouldn't take a 100k vehicle out and beat it up though I would just be mad about it
GS Audio
