diesel idea
clean454
Ok guys in 95' the 2 door tahoes had a diesel option
sooo
i really wanna put a diesel in my hoe like a 6.5L
so if i find a 95 with a diesel in it i wanna do a swap
how hard could it possibly be
swapping over the diesel stuff witch itsnt that bad (im a diesel tech)
then getting the truck refereed to it doesnt need to be smoked anymore
but how sick would that be a lifted beefed up diesel!!
i REALLY wanna do this hopefully by summer
Arctic-Rodz
RGV Texas
that be pretty cool, but those old 6.5L's werent turbo right? I think swapping a diesel into it would b cool, but making that diesel turbo would b better.
retorq
Kingman AZ
Ditto, if I was going to go thru the hassle it would be a bad ass Duramax or Cummings with an Allison behind it.
99COOP
Retired
Chicago, IL
6.5 is a turbo diesel, your thinking of the naturally aspirated 6.2
Whippled2dr
Stock
SF Bay Area
I believe in california you can't swap a diesel engine into a car/truck that was originally made for gas. You won't be able to make it a legal swap.
But I believe you can go the other way and put a gas engine into a diesel truck and get it refereed to be a smog legal swap here.
C
clean454
Hmm I'm gunna have to check it out
I really wanna do this swap
or.... Find a diesel hoe and switch vins
---------- Post added at 01:59 PM ---------- Previous post was at 12:22 PM ----------
what about that company that makes cars that run off of vegi oils in stuff
and they thro diesel motors in gas cars
ill try and find the link
but if shops do that then theres gatta be a way to make it legal
99_2door
omaha
just because shops do it doesnt mean its legal. if you want it to be legit, do all the research you can. wouldnt be a bad idea to stop by a referee station and talk to those guys. keep in mind some are more knowledgeable than others but you might get some good info. cali is pretty strict on this stuff.....its not really worth it anymore to mess around with mods that arent legal.
C
clean454
ya im not gunna do it if i cant get it legal
but i hella wanna do it
and i kno a gm6.5 will bolt up because it was a option in 95
then just swap everything over
im up for the challange
and i found a turbo'd 6.5 on ebay with everything for 900 bucks and it only has like 60K on it
Firstoneman
Northern Michigan
Did you ever do this?
Thnx. D
moto
