AC troubleshooting Help Needed
Rob Scariano
Omaha
I have a 99 OBS 2 door Tahoe.
The AC compressor and clutch works but only when I apply 12v manually. I've tried re-charging the system. I've tested the AC control switch, which works.
Is there anything else I can try. It worked fine one day then it all of a sudden stopped. I've changed out the relay and that didn't help. So I'm thinking that the issue is somewhere else.
Any advice would be greatly appreciated.
Rob Scariano
Rob Scariano
Omaha
I forgot to add that I did check the R134a. The pressure is where it needs to be.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
What about the pressure sw? What've you checked that? If it's dead its the same as reading no pressure in the system
Rob Scariano
Rob Scariano
Omaha
I haven't tried that yet. Is there a way to bypass it to see if that is the problem?
sumo
rhode island
Ok hove you check fuses? I assume the light on the control panel comes on? Also check the relay. Pop in another relay or swap one from another location to see if it will work. There is also a hi press switch you can check. Make sure the connection is good there. Other possibilities could be a broken/bad connection before the relay so the system will never energize the relay. You could also have a bad control panel, or pcm. The problem sounds to be o the control side of the compressor. Something is not telling the pcm to supply ground to compete the circuit.
Since you can force the compressor on, it's not the compressor as it's always has power and ground available.
Chris1stgenali
Saint Paul, MN
I had a similar issue, tried swapping the relays, same thing, so I bent the prongs on the relay a little bit and put it back in, wala
briannorris
