Will axles from early 80s k5 fit for sas swap
skyhighsami
I have a built 12 and Dana 44. I was thinking since so much of the front end needs to be replaced on mine what if I used these? Locking hubs, lockers and geared with 4.56 or 4.88. I will check tomorrow. I'm afraid 4.88 would be too aggressive with a 35" tire
skyhighsami
skyhighsami
Nevermind they drop on the passenger side and I'd need a driver's side drop
96ProCompTahoe
IN
seems the usual front axle is pulled out of older f250 or f350 used along with the FF 14 bolt GM rear
rabbiporkchop
Pennsylvania
buy a np241 from an 88-91 blazer or suburban, then you can use chevy axles
agmanw8n
