Wife surprised me with some swaybars for Christmas
MrsMonte must like you. I'm jealous of your Hellwig sway bars. I have done the Belltech 2/3 drop on my Suburban about a year ago and I have been trying to find the rear Hellwig sway bar but everybody has it on back order. Every time I order one the order gets canceled.
sd truck springs is hellwigs main distributor
slupie
Bartlett, IL
I know, I called them in November and they told me that the Hellwig 7740 is on back order and they will drop ship it once it is available from Hellwig. I found few on eBay earlier this week and took a chance at ordering it and it came in on Friday. I just have to order the front one now and wait for a weather break in the land of rust and corruption.
MrMonte
MrMonte
I have already put 5,000 miles on my lowered + Hellwig swaybar setup and still loving the transformation. No rubbing/noise from the swaybars so far.
Here are some pics after I adjusted the supplied endlinks to the rear Hellwig swaybar. I ended up removing the lock nut and making the rear links as short as possible and the rear swaybar is close enough to being parallel to the ground for me. I did spray some WD40 on the endlinks to make the adjustment of those long treads go easier + I just hit the 80K mile mark on my Yukon underside is well passed due for a detailing.
Danyi2170
San Diego
Here are some pics after I adjusted the supplied endlinks to the rear Hellwig swaybar. I ended up removing the lock nut and making the rear links as short as possible and the rear swaybar is close enough to being parallel to the ground for me. I did spray some WD40 on the endlinks to make the adjustment of those long treads go easier + I just hut the 80K mile mark on my Yukon underside is well passed due for a detailing.
View attachment 392489View attachment 392490View attachment 392491
Looks like you also adjusted the sway bar. How does the new position feel compared to when you had it in the middle?
Multnomah Falls
I am curious about the difference, since I am in the middle and have yet to adjust to the stiffer setting for a roadtest. I think if I do that, I will also need to air up my tires too.
MrMonte
MrMonte
I had no complains with the middle position but the inner position has a better feel to it. It's still so impressive how well the Yukon handles now and I drive on curvey backroads often.
GranPrix
What's the part number for the rear bar? I only see the front on their website...
MrMonte
MrMonte
I adjusted my rear ride height sensors which dropped the rear 3/4" which make the ride even better. Now from fender to ground I'm Front 34", Rear 35 1/4"
robbrown415
