What's Under the Center Console?
ugadawgs311
I'm trying to run an iPod wire from my new radio up into the center console. I'll have to drill a hole in the console in order to get the end of the wire in there (I want to keep the iPod stored in the center console). My question is, does anyone know what's underneath the center console? Is it safe to drill a hole down there? Should I do it on the side instead? If anyone has any help/suggestions, they will be greatly appreciated!
zach2011
Platinum Member
Pull out the center cupholder area (held on by clips) and look around.
carcrz
Georgia
drill the side, you might pinch your wires if you drill the bottom. JMO
noob
New Orleans
Does anyone have instructions to remove the center console? I want to run some wires under there up to the center stack. I have a 2010 escalade, but im pretty sure our interiors look 90% the same.
SabrToothSqrl
center console
check out the JL Audio web site
look for the stealth kit for your car, the one that puts a 10" up front.
it should have instructions on removing it...
---------- Post added at 12:46 PM ---------- Previous post was at 12:44 PM ----------
http://mobile.jlaudio.com/pdfs/12371.pdf
tali
