What does your freon sticker say?
Tylus
South GA
2015 Tahor
42,0xx miles
AC quit working. Lost the charge. I had the recall done to remove refrigerant about 2yrs ago. I believe they are also supposed to check a fitting about mid-body, and replace the sticker under hood.
Dealership wants $175 to install dye and find issue. I have the equipment and will do myself. But don't want to overcharge system. And frankly, I already have evidence prior Dealership faked 2 recalls. So I'm 1/2 expecting they did on the freon one as well. Current Dealership "diagnosed" the issue by looking through grille. Said they couldn't find it. When I dropped the skid plate today I found a flathead, rocks, and a dessicated mouse. So the obviously didn't touch a damn thing in the 4hrs of diagnosing they performed
Current sticker looks like original. What does the sticker say for you guys/gals that have also had the recall done?
Tylus
Tylus
South GA
Nothing? surely someone has the new sticker showing correct freon levels
Tahoe14
Central Fl
It was a TSB that the sticker be replaced. They did it on mine but I had to Lemon Law it. It is located under the hood and it will state how much freon the AC unit should be charged with for proper operation. Some owners may not even know that the Dealer replaced it. Update: The sticker is located on the large plastic cover over the radiator just behind the grill. Mine says 0.550 kg and with pag oil 0.820 kg. Mine is a 2017.
513Tahoe
